查看: 3041|回复: 0
[民用净水] DENISON 泵
发表于 2009-10-13 14:09 | 显示全部楼层 |阅读模式
DENISON 泵
$ [0 g/ p9 N* T& k- u1 p泵 PV29 1L1D C00
) l' o' A; F) ]  T6CM-B05-3R00-C1
9 i# {5 n2 q! @- |  M4SD 128 3N00 B502" P1 ~' ^$ r; n) _( j6 I
  M4SD 055 3N00 A502+ a: ]* Y1 E$ J- Q9 U
双联泵 T6DCM-B45-B05-3L00-C14 I9 P  q# I: G6 Y" _
  T6TDB-014-B05-1R00-C100
- j* h( x/ r" _0 y9 B  T6DC-045-022-3R00B1
) f* R" [0 O: r! k$ {+ j% d  T6EDM-066-B42-3L00-C1
# g6 Y  ]$ s$ M( x7 h! E5 ^: E2 S/ I  T6CCM-B22-B22-3R00-C14 k8 T4 @  X, e3 v0 i% ^
  T6CC-025-006-5R00-C100
4 w4 H9 u, y& \7 g' ?! g$ J3 @; R( ]  T6CCM-B05-B05-1L00-D100
3 n+ `2 w2 G$ g0 q0 |9 F5 P  MODEL T6CC-025 008 1R00 C1007 o+ k6 C* b: F$ C  J& _: \
  T6DCM-B45-022-3R00
. P$ E' B" \$ {% Y; e双联叶片泵 T6DCM B35 B22 3R1101- |$ L& ~. Z8 Y) I* h! G* Z7 o
     T6EDM-052-045-1R03-B1-J224J349
/ q! w  |1 O& P     T6DCM-B42-B06-3R13C101! }9 f8 s8 R' {. `/ Z
     T6DC-050-022-1R00-C111
1 U/ z8 F( v/ F: R$ M叶片泵 T6ED-052-048-1R03-B1-J224
4 {6 y! u; q4 O7 X: u- Z, H  T6DCM-B50-B31-3R00-C1' }8 }1 [5 g- }7 f( ^: G6 S+ a
  T6E-066-1L02A* @. u) a8 y8 @3 e! H1 q+ D
  T6D-050-2R02-B1
4 v  R/ {* N8 Y+ p液压泵 T6EC-062-025-3R13-BIMZ
, H: s4 L4 \3 Q1 l" l  TCC-010; Y5 G, Y( A) J- D
柱塞泵 PV6、PV10、PV15、PV20、PV297 M& x8 z* w3 T4 P8 H7 `5 O/ o. y- o  ?
开式回路柱塞泵 PVT10 PVT15 PVT20 PVT29 PVT38 PVT47 PVT64% T. v+ ~' C5 z  J! M
T6E-0521R03A1- d: x/ M" t: r& [+ K
  PVB6-RSY-21-CM-11- S- |, M/ x! g
搅拌马达  7R0240MS060AAAA
4 O9 `& |; G4 C+ N7 `& o0 \% B" O马达  M4SC 055 3N00 A502* `& X' C+ q' x# x
      0MS200151F0504-3/203803N454C+ D: g; ?) k* f9 x% T& f! C7 e3 b
液压马达  M11G3N1A02/013-48694-0
( i0 D% g5 b8 o& J* r柱塞泵0 h% O8 @1 D' w" i% ?* d4 \5 i8 u* G9 H0 v
PV20-1R1D-C02,PV20-2R1D-C02,PV20-1L1D-C02,PV20-2L1D-C02,
$ s4 b; c: @( y2 K+ j9 S# F$ u; |PV20-1R5D-C02,PV20-2R5D-C02,PV20-1L5D-C02,PV20-2L5D-C02,7 ^3 d# R+ W4 X8 O  w
PV20-1R1D-F02,PV20-2R1D-F02,PV20-1L1D-F02,PV20-2L1D-F02,; K* J; S5 h! M- P3 V0 G. O7 K
PV20-1R5D-F02,PV20-2R5D-F02,PV20-1L5D-F02,PV20-2L5D-F02,) C; @' V, ^6 H
PV20-1R1D-L02,PV20-2R1D-L02,PV20-1L1D-L02,PV20-2L1D-L02,
( E( b0 L- c4 SPV20-1R5D-L02,PV20-2R5D-L02,PV20-1L5D-L02,PV20-2L5D-L02,' Z/ i  `0 q8 t. B, {; R' E
PV20-1R1D-J02,PV20-2R1D-J02,PV20-1L1D-J02,PV20-2L1D-J02,- _5 X- z" E* ^6 Y# g
PV20-1R5D-J02,PV20-2R5D-J02,PV20-1L5D-J02,PV20-2L5D-J02,0 Y  o; C) n0 K6 _
PV20-1R1D-K02,PV20-2R1D-K02,PV20-1L1D-K02,PV20-2L1D-K02,
8 C5 {: Z3 }& \( Q6 H, WPV20-1R5D-K02,PV20-2R5D-K02,PV20-1L5D-K02,PV20-2L5D-K02,2 Z6 m. |5 D4 j# I) ]
PV20-1R1D-C00,PV20-2R1D-C00,PV20-1L1D-C00,PV20-2L1D-C00,7 ~6 @3 K) s- ^) o. e' ?
PV20-1R5D-C00,PV20-2R5D-C00,PV20-1L5D-C00,PV20-2L5D-C00,
5 X) X4 Q/ W# j9 }PV20-1R1D-F00,PV20-2R1D-F00,PV20-1L1D-F00,PV20-2L1D-F00,
7 l! b7 z+ L# L, d# H$ ?PV20-1R5D-F00,PV20-2R5D-F00,PV20-1L5D-F00,PV20-2L5D-F00,6 m/ @  b. l- n) i0 Y! Z$ u
PV20-1R1D-L00,PV20-2R1D-L00,PV20-1L1D-L00,PV20-2L1D-L00,' a  ^$ C. V7 ~1 b$ \
PV20-1R5D-L00,PV20-2R5D-L00,PV20-1L5D-L00,PV20-2L5D-L00,
% d4 C7 R% y% N  @' `5 iPV20-1R1D-J00,PV20-2R1D-J00,PV20-1L1D-J00,PV20-2L1D-J00,# ]) }+ o  X+ M
PV20-1R5D-J00,PV20-2R5D-J00,PV20-1L5D-J00,PV20-2L5D-J00,
' s/ Q9 _- r1 ^* P# o( j( TPV20-1R1D-K00,PV20-2R1D-K00,PV20-1L1D-K00,PV20-2L1D-K00,
4 V! ~+ \: u7 l* k) f" a; @PV20-1R5D-K00,PV20-2R5D-K00,PV20-1L5D-K00,PV20-2L5D-K00,/ I4 X. K2 Z% u7 A! |
DENISON丹尼逊PVT系列开式回路用轴向柱塞泵
/ J9 I- b! x& y% e, [4 zDENISON丹尼逊PVT系列开式回路用轴向柱塞泵,帶尾驅動
3 @, z6 N" v( x" s; E7 e: M+ v* bPVT6 - 14.4 ml/rev. PVT29 - 61.9 ml/rev.
# A9 p' V: M( I3 F9 E; l. A) ^PVT10 - 20.6 ml/rev. PVT38 - 80.0 ml/rev.
, z0 A, ]/ c1 l% _3 S( wPVT15 - 34.2 ml/rev. PVT47 - 100.0 ml/rev.! w8 S4 @: [; ^( m, I
PVT20 - 42.9 ml/rev. PVT64 - 130.0 ml/rev.
5 I9 L1 w0 w. H* f; c$ sDENISON丹尼逊PV系列开式回路用轴向柱塞泵1 c" T+ D* E2 J) H; C- ^$ k
此系列泵广泛应用于发电站及工业设备上,品质优异,性能可靠。共有PV6、PV10、PV15、PV20、PV29五种型号,排量分别为14.4ml/rev、20.6ml/rev、34.2ml/rev、42.9ml/rev、61.9ml/rev。其中除PV29最高工作压力为275bar外,其余型号的最高工作压力均为310bar。7 S9 i: G( \- v& \' u
DENISON丹尼逊T6CR, T6DR, T6ER系列带尾驱动单联叶片泵
, {  L7 D, }8 c) L- k$ V5 x' _. t4 eDENISON带尾驱动单联叶片泵
1 ~3 P+ g) U) d% D最高压力:240-280 bar。! e# R& \$ g) w  u# ^* ~8 Y3 R
最大排量:100-269 ml/rev。
0 m% l, B, H  i* H" Q4 F/ `+ A. U$ U8 P示例型号:T6DR-031-1R00-B10-A1。
8 m0 D) r. U" m/ a1 B( I+ WDENISON丹尼逊T6DCCR, T6EDCR系列带尾驱动三联叶片泵
) ?, d! i6 v) u) VDENISON带尾驱动三联叶片泵
+ O: R; @5 Z8 \" |最高压力:P1:240 bar,P2:280 bar,P3:280 bar。
8 `# s3 N) _+ W$ ~, z  r6 Q$ w最大排量:P1:158-269 ml/rev,P2:100-158 ml/rev,P3:100-100 ml/rev。
2 W$ B' P2 e9 H' G示例型号:T6EDCR-072-042-020-1R00-A1F0。
5 M$ Q% J) p2 y  n/ UDENISON丹尼逊T6EE系列带尾驱动双联叶片泵
2 H& Z! N; h$ P6 |0 NDENISON带尾驱动双联叶片泵/ e/ K  L2 W) X% M" ^
最高压力:P1:240 bar,P2:240 bar。
' s4 d% |% \* y1 u最大排量:P1:269 ml/rev,P2:269 ml/rev。3 d  Q5 n' `+ p+ E4 z: z
示例型号:T6EE-072-045-2R00-A10-M0。
& I! |) `# K2 ^# r, mDENISON丹尼逊T6H系列混合泵
$ q; @" r/ i! q- M3 F' }DENISON混合泵 T6H20B, T6H20C, T6H29B, T6H29C, T6H29D 系列
+ b2 u8 t! Y, J6 S( d+ G' r+ R$ y最高压力:P1:210-280 bar,P2:280-300 bar。
4 P& s4 A- D: ^  M6 S最大排量:P1:43-62 ml/rev,P2:50-158 ml/rev。
, t% Z4 }. j, b9 P* c' Y  e9 l示例型号:T6H20C-020-1R1B-F00-2M1-00 。
1 ]/ Q" y( t6 sDENISON丹尼逊其他叶片泵:
' e+ @4 a9 p/ S2 [6 T+ d2 vDENISON丹尼逊T7B, T6C, T6D, T6E系列单联叶片泵6 G: ]6 s& ?; z2 T
DENISON丹尼逊T7B, T6C, T6D, T6E系列单联叶片泵最高工作压力从190bar至320bar可选,最大排量从40ml/rev至269ml/rev可选。泵的重量从7.0Kg至43.3Kg。此系列叶片泵主要用于工业和行走机械。 示例型号: T7B-B10-1R00-A1M1, T6C-025-1R00-C1。
( m3 O% X0 m1 M+ \( F, vDENISON丹尼逊T7BB, T67CB, T6CC, T67DB, T6DC, T6DDS, T67EB, T6EC, T6ED T6EE系列双联叶片泵0 E" Y( E# ^0 t# x( o
DENISON双联叶片泵% C8 K! }! j* v) K
最高压力:P1:240-320 bar,P2:240-320 bar。' B# h# N# s8 r5 K# w
最大排量:P1:50-269 ml/rev,P2:50-158 ml/rev。
5 |* [4 I# p, ^! c# F- |示例型号:T6CC-025-020-1R00-C100, T6DC-045-014-2R00-C1。' E# K4 z8 f+ x! l) x% [3 G- b
DENISON丹尼逊首相系列开式回路用轴向柱塞泵
) K# u. e3 ~5 I9 H* O+ J2 |8 @( P( {P080 - 80.3 ml/rev, 500 bar
; v0 f. i  v4 OP110 - 109.8 ml/rev, 500 bar2 @; g; B  q1 l. T# a
P140 - 140.9 ml/rev, 500 bar( w/ b8 C/ C" w+ J
P200 - 200.0 ml/rev, 500 bar) O$ [4 `6 Z2 n6 F2 L
P260 - 262.2 ml/rev, 500 bar
$ k6 ?5 e0 E" S8 m2 c% ]  pDENISON丹尼逊世界杯系列轴向柱塞泵2 _; W( ^1 k! M+ [
P6W - 98.3 ml/rev, 420 bar1 K& q; L0 p; `, w1 w
P7W - 118.8 ml/rev, 420 bar6 s9 E" ~3 |3 l9 \
P8W - 131.1 ml/rev, 350 bar- y* Y: ^8 e# h) w7 n
DENISON丹尼逊金杯系列开式及闭式回路用轴向柱塞泵
9 w" W- |4 J! d7 J+ |; y8 MP6 - 98 ml/rev, 420 bar P11 - 180 ml/rev, 420 bar
& c- ]( K* J/ ]- F+ M% p) [P7 - 119 ml/rev, 420 bar P14 - 229 ml/rev, 420 bar; B) ?( y0 ?3 c
P8 - 131 ml/rev, 350 bar P24 - 403 ml/rev, 350 bar8 f) l9 p) C- `' p6 V
手機 :13564131444顧先生! Y- B- W% h. ?. N9 ?% j
傳真 :021-60911079
3 O% E4 o- N: o  n7 e. c郵箱 :ok_114@126.com
GMT+8, 2025-12-16 10:28 , Processed in 0.112462 second(s), 21 queries .
