查看: 3640|回复: 0
[进口产品] [FW:Initial Setup for 9100SE] 9100SE的初始化安装
发表于 2005-7-25 21:06 | 显示全部楼层 |阅读模式
本贴 转发自FLECK官方论坛,原作者是woodman17
Hello,
I am about to install a 9100SE in a new house and need a sanity check on my setting for the regeneration program settings. I went through the calculation from the FLECK manual and the only time I changed from the default was the brine tank fill. My desired salt setting is 6lbs per ft3 of resin. I have two 12 X 52 tanks each with 2 ft3 of resin. The 9100 valve has a sticker that says the drain line is 3.5 gpm. I left the following default setting as delivered:
Backwash 10 minutes
Brine and Rinse 60 minutes
Rapid Rinse 10 minutes
The Brine tank fill is the only setting I changed. Here is where I think I need a sanity check. Using the formulas from the book, 1 gal of water desolving approxomately 3 lbs of salt and I need a total of 12 lbs to regenerate the 2 ft3 of resin.
我在一个新房子里装了一台9100SE,需要检查其再生程序的设置,我看了FLECK手册中的计算步骤,只将一个时间从默认值改动了--盐水重注. 我希望的设定是每立方英尺树脂用6磅盐,系统有两只12 X 52的树脂罐,每罐装有2立方英尺树脂, 9100阀有一个瓶颈:排水管流量是3.5gpm.我使用的默认设置是:
反洗 10分钟;吸盐及慢洗 60分钟;快冲10分钟
盐水重注是我唯一更改过的一个参数,这里我想我需要检查(确认)一下,按照手册上的表,1加仑水可以溶解大概3磅盐,我需要12磅盐来再生2立方英尺树脂,如果系统的注水流量是1gpm,那么我需要4分钟时间进行盐水重注,与更改其他再生设置一样,这些设置将非常有用.
9000/9100/9500手册中没有任何更改参数的细节,只是用其计算再生所用的总数
If the unit has a 1 gpm refill rate I assume that I should set the Brine Tank Refill for 4 minutes (12lbs / 3lbs/gal = 4gals). Advise on these setting whould be greatly appreciated as well as suggestions for changing the other regeneration settings. The 9000/9100/9500 manual does not go into any detail about changing the other setting it just uses them to calculate total gallons used for regeneration.
Thanks
GMT+8, 2025-12-22 06:37 , Processed in 0.067148 second(s), 18 queries .
